Need Advice on Cutting cowl in 33% AW Edge
I've got the 33% Aeroworks Edge 540T ARF with a ZDZ 80 single and BCM Pitts muffler installed (along with 3 pounds of lead on the nose - Doh!). I have the cowl cut so that it will JUST fit over the head & pipes. How much more (if any) will I need to expose the cylinder for cooling, and should I enlarge the outlet as well? Also will baffles make any difference in the single inverted installation?
The pics are at http://www.ashfordhome.com/draders/edge540t/
Your advice is much appreciated.
KD
KD
Cowl Cutout
You will need to enlarge the inlet to give it a direct shot of air. From looking at the front of the plane, I would cut out enough cowl to allow air to hit the fin closest to the engine and about 7/8 to the outside edge on each side.
You will then need around 3 times that opening size for the outlet air. Baffle it so no air is allowed around the engine only through the fins.
