Xicoy telemetry pump factor on K180 and K210
Has anyone found a suitable starting 'pump factor' to use with the Xicoy telemetry when running either of these two engines. The manual state a default of 400, but I am sure many guys have by now found the right factor to use. I know that the tank volume can be adjusted, but that is not ideal and will only be meaningful at very low fuel levels.
Thank you for your help.
Jan
Jan
My Feedback: (114)
Hi Jan - can't answer your question, but was wondering if you have been able to access the menu portion of the advanced setup for the telemetry adapter.
Otherwise, It works great...sends all data to the Jeti for viewing....BUT I would like to go into the advanced setup for the telemtry adapter (using the Kingtech/Xicoy system analyzer as described in the manual) and can't seem to get it to work. I'm trying to set the tank capacity and pump factor in the telemetry module.
When I hook up the telemetry adapter to the system analyzer with a RX battery, the system analyzer just powers up in "RC Model Analyzer" mode instead of showing "Radio Model: JETI" per the telemetry setup manual. From there, none of the buttons do anything on the system analyzer... The red LED on the telemetry adapter is on as it should be per the manual.
Any ideas?
Any ideas?
