KT 140 kero start
KT 140 kero start
I would appreciate help with a problem with my KT 140 kero start.
the turbine goes through the start sequence up to Burner on, turning 4k revs. then drops back to Circa 1900 revs, and then a message appears ignition failed???
the battery is fully charged, and circa 10hrs run time, this is the first time I have had a problem starting.
thanks
thanks
thanks
thanks
just worth checking out.
