Heckler ARF engine size?
RE: Heckler ARF engine size?
I love the Heckler. I have one and one more in the box just in case. I use a GMS .47 or an OS .46AX. An APC 11.5-4 prop seems best for me.
I found the engine leaned out so I side mounted. I also moved the battery back behind the wing and mover the rudder servo to the top of the fuselage in front of the fin with pull-pull. This saved me when I broke the fin off in a full power blender and the pull-pulls held it in place so I could land. Now I have wire tail braces.
Thanks for the Info. Did it weaken the rear of the plane by putting the servos in the rear. Also I heard that thay don't make the heckler any more so the supply is about gone. I just ordered the one I have now. Also what size of a 4 stroke would you suggest to use
This the web site that the Instruction Manual had. http://www.wing-tote.com/ I ordered mine from Hobbyworks.com
