Panavia Tornado 1/6.5 Swing Wing
Tornado 1/6.5 kit from a guy in Italy very nice quality work you would expect out of an Italian produced kit
Carbon reinforced formers, hysol used on all bonds, with very light composite structure.
1/6.5 scale
84.5" Wingspan
92" Length
34-36lb Single Turbine
Functional swing wings completely set up and operational (I have a video of the operation PM your number if interested in it and additional pics)
Leading and trailing edge wing flaps already installed just needs servos
Elevator mechanisms already installed (work as elevons)
Comes with gear and brakes (needs tires and nose wheels)
Fuel cell and header tank
Canopy and cockpit kit.
Functioning speed brakes and mechanism (needs to be installed)
Bifurcated pipe set up for single turbine 34-36lb thrust
All the hard complicated work is done but will need some scratch building skills to finish this model up like mounting elevator servos, gear doors, hatches, nose cone, and canopy. All the hardware and parts include are shown in the picture. You will need a few things to finish like door cylinders, retract valves and air lines, misc hinges and small parts. (basically all the stuff we replace anyway from most of the other cheap kits we assemble)
This kit is only about a year old but I have so may other projects that need funding I have decided to sell. I have bunch of pictures including some in the build process that I can email or text if interested.
1/6.5 scale
84.5" Wingspan
92" Length
