Choke setup on DA 50
Im new to gassers. I just built a WM 80in extra and fitted it with a DA 50. A few friends of mine have the choke activated thru a manual nyrod mechanism. Is that the right way or do we do it with a servo? Pls advise and also show engine setup photos if possible, especially choke servo pics. Also, is a 14 oz dubro tank enough for 12 mins flights? Where do we mount the pipe coming from the tank exhaust outlet? what refuelling mechanisms do you all use?
My Feedback: (10)
RE: Choke setup on DA 50
Also, is a 14 oz dubro tank enough for 12 mins flights? ?
but i plan on giving the throttle a nyrod setup. can i give the choke a 4-40 metal pushrod with a dubro clevis? i hear there's a viration-R/F interference issue that i'm to look out for. whats that? could i hv precautions to keep in mind while setting up a gasser?
ON, CANADA
Here are a couple pics of two similar choke setups. They are connected to the choke with dubro swivel ball links. One rod is obviously metal and the other, more preferable method, is carbon rod. You just JB weld the carbon rod into the ball link. I also screw on a nut on the end so I can grip it. Then just velcro the rod to the ignition lead and you are good to go.
Make sure if you use a manual choke that you install a cutoff switch or similar.
Cheers,
John
Cheers,
John
