Fuel Type
MB, CANADA
RE: Fuel Type
"generally" 10% blend is OK to run in any gasoline powered vehicle. A slight tune may be in order. It will clean everything out. Others may have a different opinion. I unfortunately do not have too much of a choice when it comes to fuel and blends as almost every fuel station has a blend percentage of some sort. Governement is making it mandatory for all fuels to have an ethanol blend in the next year.
RE: Fuel Type
I have heard of people in the US using camping petrol, I believe Coleman to be one brand that has been mentioned, you should be able to buy it fairly easily, so might be a good alternative for you to use for your model.
Glenn
Glenn
RE: Fuel Type
ORIGINAL: glennb2006
Glenn
Glenn
RE: Fuel Type
with ethanol blend fuels just on safe side run good quality oil
ethanol which is an alcohol base can cause cylinder wall wash down but i doubt 10% will be a worry also some oils are not compatible with alcohols tend to seperate from fuel
RE: Fuel Type
this would be interesting to watch with the alky/gas/oil additives. one might take a clear glass jar and put your oil/alky/gas mix in and let it sit and see just how fast or how much it seperates and how much shaking it takes to reconstitute the mix back together. i ran camp fuel/castor oil so it was never a problem
HI
RE: Fuel Type
I don't know about where you live, but here I heard that we can get non ethanol gas from the boat fueling dock. I was at a local small engine repair shop and the ethanol is causing alot of carb related problems it's eating away some of the seals in the carb. I'm not sure what seals and unsure how long it takes for the problems to araise.
MB, CANADA
RE: Fuel Type
ORIGINAL: KNahinu
generally this is found in higher concentrations of ethanol like E85 as an example. What the actual problem with ethanol blends is that it will remove any varnish from old gasoline fuels left in the lines and tank. This cloggs fuel filters (a good thing) but if any varnish (that yellow gummy stuff found in cars that sit for a month or two) is found in fuel bowls of carbs or even on the accelerator pump diaphragm in the carb it tends to clog jets and journals in the carbs. If the engine is at higher rpms, the varnish letting go in a 75-100gph fuel pumps found in some larger engines will actually pinhole diaphrams and gaskets within carbs and fuel injectors causing the deterioration described above. 'generally' 10% blend will barely soften a gasket/seal except where an ageing one currently exists. I've been running 10% blend for eons and w/o concern. Start running 35% or more blends, then think twice...
RE: Fuel Type
camp fuel mixes the same ratios as regular gas i ran Maxima 927 castor at 5 ounces to the gallon. castor oil will flow to a hot spot where regular or synthetic oils will flow away from hot spots
