pull - pull set up aluminum bellcrank
Hello Guys i got a concern about aluminum bellcrank coupled to a steel clevis on a pull pull set up if this will generate noise for the receiver ?Bellcrank will be operated by a short heavy duty bar connected to a nylon servo arm .
I use an aluminum bellcrank for the all-moving horizontal on my Balsa USA Eindecker.
There's that with the steel pushrod and clevis, and 6 steel cables (4 for the horizontal, 2 for the vertical) running to the rear of the plane, with the aerial there also.
No problems.
No problems.
