The New PTI Goliath Pro Rock 12 Rtr
Hey there i have owned numerous crawlers and fabbed my own chassis but being a working man i had to sell all my crawlin stuff.So im looking to get back into the sport and i was wondering what everyone thinks of the Pro rock 12 Rtr by PTI because I am very set on getting it.Also tell me any things i should get or mod on the truck. batts or tires and running gear.
ON, CANADA
RE: The New PTI Goliath Pro Rock 12 Rtr
I wonder how come nobody knows anything about the Golliat Rock Crawler; i'm looking for information about this vehicle, the
little info i found dont really tell me anything thats why i come to the forum for, Does anybody knows anything. The link dont say that
much either. Only user's can tell. Is it any good, it is worth thre investment cause aint cheap either. So if anyone can help i really appreciate,
Here's mine:
I've owned this thing for years. It started life as the original MMT (1/18th scale) version with the 8.5 wheelbase. As far as the Pro version goes, it has all the mods mine does except for a gear reduction unit and CVDs
The Goliath is direct drive, meaning it has a center-mounted spur; no transmission. In order to get it truly crawler worthy, you have to add a gear reduction unit. PTI sells one or you can get one from RC4WD or modify an airplane gearbox like I did originally or replace the whole assembly with a multi-gear tranny like the Axial tranny (with a slipper clutch) or the RC4WD R2.
The second bugger is the axles. The gears are plastic. They have to be shimmed carefully to keep them from grenading. And even then, you have to be careful. I reconfigured the center spur with slipper pegs to make my own slipper clutch setup to help save the gears. It worked very well. Rarely stripped a gear. A slipper is almost mandatory. If you use an R2 tranny, which has no slipper, you have to be very careful with your driving and not get your wheels bound up too bad. Once I swapped in an R2, I started going through axle gears again.
hi:
Can anyone tell me what aftermarket parts i can get for my Golliat Crawler , im new on this and would
like to improve the capabilities of the Golliat. Any help is appreciated
There are upgrades available through PTI. Aftermarket support is not very good. With some ingenuity you can get various parts for other vehicles to fit the Goliath. For example, I managed to get TLT alloy knuckles to work on mine; wasn't easy though.
http://www.ptiracing.net/hop-up.php4
The new Goliath Pro 12 RTR will feature an aluminum transmission. It will also be available as an upgrade for the other Goliaths.
Were doing a review of it on RCU within the next month or so.
Matt
Matt
HI: KB
NEED some advice got my Golliath ; Now can you sugest me what motor and esc should i use; this is not for competition just for fun any advice will be apreciated
If you don't have the gear reduction on there, your best bet is gonna be to get some sort of super high turn motor; something like a 75T lathe motor and bump up the voltage. A 3-cell lipo would be ideal. And get the largest spur you can fit in there which is around 90T and a 12T pinion. For a speed control, get youself a Castle Mamba Max or maybe the Sidewinder. The Novak Rooster Crawler is good too, but it can't handle 3-cell lipo. You could use an 8-cell NiMH pack though.
Need some advice on how to instal an Integy 2.5 ratio gear reduction sys. does anyone have it done
and can explain me how to do it; and if there is any modification involve . Thanks for any help i can get.
also what kind of servo should i use.[&o]
HI Everyone:
I read don't remember where that you can adapt an Evader ST Trany to the Golliath Rock crawler ; if
anyone knows how to and want to share how to install it i wil really apreciate, I have a spare one that was building for
my Evader in order to use it brushless but i can make the switch[ so if any one can help please let me know by PM. Thanks
again for the help .
FOR SOME REASON UNKNOWN BROKE ONE OF THE FRONT DOGBONES , ANY SUGESTION ON AFTERMARKET ONE THAT CAN FIT
AND COULD BE STRONGER, APRECIATE ANY HELP AND SUGGESTION.[>:]
PTI sells CVDs which I highly recommend:
The dogbones that I use in the rear are these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXLV96&P=7
Need some advice on this issue , have novak rooster with stock motor 55 ) and change spur for a 90t
still feel it goes to fast using a 12 pinion gear what should i do.
Do you have a gear reduction unit? It's pretty much a must have item on the Goliath.
http://rc4wdstore.com/product_info.p...roducts_id=427
This might be something to consider as well:
http://rc4wdstore.com/product_info.p...roducts_id=895
My Feedback: (13)
I am running a 10t pinion with a 55t motor. Mine crawls ok, but I am planning on adding the RC4WD GRU unit soon. I was able to crawl just as well as a stock Axial last weekend...followed him everywhere he went. And that is with almost stock suspension, and old Proline Mashers glued on cheapo wheels.
I have some beadlocks and Hammers on order.
