Can Anyone Recommend a Good Setup Stand?
PA
Hi, Have recently finished a 1/5 scale Pica T-28 and almost finished a 1/4 scale Ohio Sukhoi. Both will need a field assembly stand which, up until now, I haven't needed. I'd prefer one that doesn't take too much work to put together. (I'm burned out on building things for awhile ). Any recommendations or web sites? Thanks very much. JD
Check out crusadertoys.com. They have a nice arf type stand that comes assembled but needs to be finnished. I have one and feel it is a great value. It will is adjustable to accomodate very large planes as well as the smaller glow planes.
My Feedback: (132)
HI JD,
Check out Don's Hobbies in Arizona. They have a web site at www.donshobbyshop.com and advertise in the mags often. They have two real nice metal stands that work great. One is larger and has a work tray and the other is knocks down quickly for transportation, is adjustable and just works great. These are larger type stands so when your plane is on them you stand next to it to for working on your model. I believe both stands have a capacity of around 60 pounds. I love mine and have had several friends buy them after seeing mine.
Ummm.......Don's is in Salina, Kansas. Yes they would have what your looking for.
I've made several out of PVC. I have one particular configuration that seems to work out for building as well as field set-up. I have one for most of my planes.
I can relate though at being burnt on building...this building binge I've been on has been well over 2 yrs. I've got just a few months to go, and then I'm taking small(very small) vacation.
I say that now though, and something will come up. Oh well...as long as it's planes.
JDHammer
I have both the Crusadertoys and the Stand "Pro Stand II" from Don's hobby in Kansas and prefer the Crusader Toys model. It is more expensive, however it is fully adjustable to handle a large variety of different size models. The Pro Stand I and II have a fixed fuse width brackets and accept the larger size FAI planes.
BDL
BDL
Go by Harbor Freight and look for a metal tube stand. It sells for about $13. Turn it upside down and move the pivot point up to where the two legs on each end are now about 18" from the pivot point. Now get a sleeve of refrigerant pipe insulation for the legs. They now form a V that your plane can rest in. One of the cheapest, yet functional stands I have ever used. I carry mine folded up on the inside of the back door of my trailer.
Vince
Vince
Aircraft Stand
JD;
Here is mine Plans are almost finished, as doing them from the hip just wasn't giving me the exact results I wanted.
Here is a Picture with a Brand new 2M on the Stand as well as the pictures you'll see in more detail on the link.
http://www.rcuniverse.com/showthread...824&forumid=63]
My Feedback: (25)
JD, take a close look at the Hughs stand. It costs $50. I went to Lowes, bought the parts (PVC pipe) for about $10 and put it together in about a 1/2 hour. Then I got a tray that fits in between the cross bars to put all my stuff in works great.
