charging battery qusetion??
hi all im new to the rc world and have got my self two new cars .the first one is a tamiys vr6 mk3 golf that i have wanted for 10 years ,the second is a hsp xstr brushed model .
my question is about the xstr ,how long should i charge the battery for and how long should i get out of it (running time )??
think im haven a problem with my car ,i charged the battery for 8 - 10 hours the first nite and ran it the next day till it was dead so charged it again for 2 hours and ran it this morning but only got 10 minutes out of it , is this right or have i fecked it up
any help would be great on this thanks
pics to come of the vr6 as i build it !!
andy
andy
RE: charging battery qusetion??
What charger are you using?
If you are using a charger that was supplied with the car then you will need to charge overnight every time you run down the battery.
ORIGINAL: jellyjim
yep its the one i got with the car .
how long should i be getting from a fully charged battery
im running it on the road till i get the hang of driven it ,the battery is a ni-mh cs1800mah 7.2 and im not sure what the esc is ill get a pic of it later and show u fellas ,
thanks for all the quick replys on this
here guys dont know if this helps but this is thr rc car im talking about http://www.********.co.uk/xstr-elect...rol-buggy.html
Problem is your Charger and Batteries.
-Capacity of you NiMH batt is lower than the power of motor.I dont know your motor power!.So 10 minutes running time is right.
-Your charger is the common charger.This chargher can not be adjust the circuit and voltage. I think the charger has output 0.5A~ 500mah.Give you the simple formula : 1800/500 =3.5hours.
If you want to play with more running time you should change to lipo battery with 4000-5000 mah capacity.And you should have the special charger for this. Imax B6 ;Cellpro 4s ,Orion charger....
Best regard.
Best regard.
