savage x 4.6 vs t-maxx 3.3
NE
hey guys, i'm thinking of getting a nitro mt soon. this will be my first nitro. which one is cheaper in the long run. which would you choose. i've heard the savage is way tougher but the t-maxx is faster and more nimble. i'm just going to be bashing and occationally a couple laps around the local track. probably not actually racing.
thanks
thanks
KS
RE: savage x 4.6 vs t-maxx 3.3
Five gallons of fuel and many hours of run time and it is still going [link=http://www.youtube.com/watch?v=Ozozlgcw8Ss]strong![/link]
NE
also, i was looking at pull starts and they are cheaper than batteries and charger for starters. do pull starts and glow ignitors work well?
My Feedback: (10)
IL
Yes, they work well. You need an ignitor regardless though.
Roto-start will definitely help out by NOT giving you blisters like the pull-start would.
Just get 2 cheap flat-packs and a decent charger and call it a day.
If you have experience pull starters are not all that bad for bashing. I ran a pull starter on my Savage K4.6 for over 9 gallons and only had a problem with the pull starter 3 times. I all so could fire it up on command every time. I did switch to a Roto Starter as I race but for well over a year I raced with the pull starter. I never got blisters on my fingers from a pull starter.
T Max is a good truck if you do not mind replacing the engine every couple of gallons and buy all the RPM up grades so it does not break every time you hit a little stone.
