OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
AFP game commander not working with xp
Old 12-17-2004, 04:06 AM
s2gulf
Default AFP game commander not working with xp
Hi all,
I've had afp for sometime now and never had any problems using the game commander control box with xp pro. I recently installed a newer version of xp pro but in doing so, I can no longer get the game commander to work, the computer simply doesn't see it.. I've checked all connections etc etc, but to no avail..
any ideas???
thanks in advance
Matt
Old 12-17-2004, 07:55 AM
STLPilot
My Feedback: (21)
Default RE: AFP game commander not working with xp
Do you have the patch installed?
You must go into the control panel under joysticks and calibrate it there too.
See if this helps.
Old 12-17-2004, 08:07 AM
s2gulf
yepp, have the patch installed, but when I go to the controller bit in the control panel, it doesn't appear to be there... only my cyborg 3d joystick.... I can use that to control afp, but not as realistic as the game commander...
I have checked and double checked the connections etc and they all seem to be in order..
Matt
Old 12-17-2004, 08:31 AM
STLPilot
My Feedback: (21)
Is your joystick connection on the audio card?
If so this an XP issue for that card. Can you update that card with latest drivers?
Old 12-17-2004, 09:39 AM
s2gulf
The cyborg 3d is a usb connection, I'll double check the rest when I get home...
many thanks for the advice
Matt
Old 12-17-2004, 10:18 AM
STLPilot
My Feedback: (21)
So are you using a USB to 15 pin for the Commander?
Old 12-17-2004, 03:42 PM
s2gulf
No, just using the 15 pin plug straight into the game port (I think)..
Can now manage to get the throttle and ailerons to work, but not elevator, rudder or button...
I think I just need to play around with the settings in the control panel..
Matt
Old 12-17-2004, 05:06 PM
STLPilot
My Feedback: (21)
Follow these directions.
http://www.geocities.com/simblaster/sbinstructions.html
However call it "Commander" then Simblaster.
Old 12-21-2004, 07:57 AM
s2gulf
Thanks for the instructions.... All sorted now, so am happy again..
many thanks
Matt
Old 12-28-2004, 04:08 PM
captinjohn
NEED REPLY ..... Will a 9200 se 128MB PCI vidio card by VisionTek, run the AFP Deluxe. Or should I look for a better one. I did not open it yet....so I can exchange it for a differant vidio card. Thanks
