need help!!!!!!!
NJ
need help!!!!!!!
Having a problem setting up esc. here's the equip. Futaba 9C (not 2.4) Turnigy delux 100A SBEC, Sky Lipo 5 cell 2650. I set throttle trim to zero. reversed throttle control (futaba) turned on transmitter set throttle full, plugged in battery. beeped , pulled throttle down to set. My problem...sometimes the throttle works then it starts to cog for lack of a better word. it turns slowly but makes a hidious noise. Then it might work again. I set the esc to the motor specs. made no difference. I have tried other motors and esc's. Various setting and combination of equipment. Same problem. I don't get it. What's going on ??
AZ
RE: need help!!!!!!!
Check the ESC settings. It could be timing or wrong number of cells set for default. Also could be thr throttle range you have set. Try reprogramming the throttle range.
NJ
I see I omitted the type of motor used. HET 2W-25. inrunner but I may have solved the problem I was having. After building a test stand to test motors and props; for some odd reason the throttle so far is working without cogging. I previously was testing the engine without a prop. Is this common with inrunners ?
Sounds to me like someone already suggested....a timing issue.
Your ESC should come with an instruction sheet that tells you how to program each feature of the ESC. Motor timing is one of those features.
I cant recall right off...but there are usually 3 different timing option settings, one of which would be the most appropriate for an inrunner type of motor.
With a little more research on your ESC, Im sure you will be able to find out which option you need to select.
I know that Ive had some motors make a terrible loud/hi-pitchy "screeching" sound like it was "stuck" when Ive had my timing setting not set correctly.
ORIGINAL: flyhigh2
Does anyone know of a chart that compares 2stroke to electric such as how does a 46 size compare to electrtic?
To be truly successful with electric powered flight you need to understand the terms, the components and how to size power systems. It is very different from wet fuel.
<div dir="ltr" style="font-family: ; color: "><font face="Arial">EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT</font></div><div dir="ltr" style="font-family: ; color: "><font face="Arial">http://www.rcuniverse.com/forum/m_7100376/tm.htm</font>
Ifall you want is an answer and not an eduction, here is a goodchoice.
Rimfire .46
http://www3.towerhobbies.com/cgi-bin...XLWV6&P=ML
</div>
