os 55 ax for cessna 310 best prop
Hi all
I got a cessna 310 with two os 55 ax engines, os recomends 12x7 or 12x8 props to start I ran the engines with 12x7's and I was only getting 10.9 to 11.1 rpm. I think this is to much prop for this engines. What prop should I try next, I just dont want to experiment to much if there somebody here with os 55 ax expirence. thanks .
RE: os 55 ax for cessna 310 best prop
Hi friend..
Forgive the OS manuals and marketing.. All OS that i saw is very weak.. the AX´s series is only marketing..don´t have any real diference to FX series..
The best propr for your AX is the 10x7 one. Will turn around 12000rpm with this prop.
Cheers and tell me the result!
Matheus S. Almeida
Matheus S. Almeida
