Ram 1000 'plug open'... added picture
My Feedback: (162)
I have a ram 1000 that I've never run. Just installed it in a F15, went threw the setup, cycled the radio/ecu. Turned everything back on and the ecu flashes green for 1 flash then goes red and gives me the 'plug open' on the remote. I tried changing plugs to a new plug but I get the same reading. I'm also using a a123 for the ecu battery. I believe that you have to change the ecu battery size in the menu to 060???
Any ideas?
Any ideas?
RE: Ram 1000 'plug open'... added picture
try going back to a ni-cad setting with a ni-cad battery and see it the message goes away, if it does not then its most likely a hardware issue, if it does go away its most likely a setup issue.
Steven
Steven
I have a RAM 750 Plus with over 250 starts, and going to a FeiBao Hawk. I'm installing Lio-Manga. batteries. My ECU is the original one. BUT, when I called Carlos at RTI, the first thing he
asked me was which ECU was it. As soon as I told him, he oriented me that it should be a class 4 or 5 ECU. Those are the ones for the new batteries. So I sent mine for upgrading.
That's my .2 cents
Hector
That's my .2 cents
Hector
My Feedback: (162)
It was my messup, not really a fix.. I kept getting the plug open on the screen. I plugged in another good plug but just grounded it to the turbine and tested it... It kept giving me the plug open. I finally decided to do it right and installed the good plug and it worked right. Evidently I wasn't getting a good ground. I did notice that I had to play with the plug lead for a second to get a good connection as well..
More or less I don't think that there was anything wrong other than the installer []
