BH Hanson Clutch???
PA
BH Hanson Clutch???
Anybody running the BH Hanson clutch set up??
Mine is draggin a little bit I am wondering if there is something wrong with it or if it needs replaced?
RE: BH Hanson Clutch???
could be the spring on the shoes that needs replacing also check the bolts
holding the shoes in place if they come lose it won't disengage. i had this happen to me
i run the same clutch good products
PA
Can you explain how to get the clutch and stuff out of the boat?
I see there are three screws on the housing on the front of the engine that hook the coupling up is that where I start?
PA
Well I got the clutch out of the boat it has no springs!
It's just a race type aluminum finger kind.
I hate it
Going to go to there new pro clutch cause it looks to be less maintenance.
Plus the drive shaft got broke lose when I was getting the old clutch out so I will have to re seal that also.
This is always fun buying someone elses junk.
Oh well
I hate it
Oh well
