EGT leads extension
EGT leads extension
For some application the EGT probe leads may be too short to place the ecu in specific required location. Since the AV8R and other similar trainer are very famous for first turbine jet, extension on the EGT lead may become necessary. However, we don't recommend this extension but if unavoidable, you must use special EGT probe lead of the same specification. If the lead is extended with regular wires, the resistance and EGT reading changes. If you need extra length EGT lead, please let us know when placing order and we can provide extension to all leads.
Remember that unauthorized modification will void the warranty.
Kraivuth S.
PST Jets
Kraivuth S.
PST Jets
