Electric trouble
Electric trouble
I have been into flying RC Planes for over 35 years and have always did gas/nitro motors... Well, I decided to buy a Cessna 310 and went electric... It sounded simple enough and at first it seemed it was as I was able to get everything to connect and move... HOWEVER, now after getting all my servo leads ran and tucked into all the areas I wanted them in, I got to plug the motors in and I don't have any rotation of the props...
I have a constant BEEP, BEEP, BEEP, sounding off when I plug the throttle into the receiver, but I can't get motors to do the BEEP, BEEP thing they are suppose to do to get the props to turn... It's probably something simple I am over looking but am about to pull it apart and wait to find someone that can figure this thing out, but thought I would ask here before doing that, as I am sure there are many experts out here on the electric set-up that I am not familiar with...
I have also tried a different radio and receiver and have the same results... Any advice/help would be greatly appreciated... If someone with experience and expertise wants to chat, I can share some video or we can chat via video so you can see what I am running into....
Thank you in advance and please don't laugh at the old codger here, as this is not my cup of tea apparently...
Srumpy1958
Srumpy1958
Your controller(s) situation is not yet clear to me, so bear with me:
Each brushless motor needs its own brushless controller and each controller/motor combination needs to be calibrated.
A brushed controller o.t.o.h. can handle more than one brushed motor.
Several other possible causes and solutions:
Motor stuttering? Won't run?
The controller(s) is trying to tell you something in beep/morse code, using the motor as a poor loudspeaker.
Look up or google (make/type manual/instructions beep code) the code, several codes.
In case you have a Futaba transmitter, Futaba's need to have their throttle channel reversed.
The controller is using the motor as a (poor) loudspeaker. In a loudspeaker a coil moves in/because of changes in magnetic field, same for motor. In a motor magnets move because of changes in magnetic field.
Some well-structured reading for rainy/windy days, including e-flight_101 & 102, and some handy e-tools.
Will save you, and us a lot of questions. Notably the 'what went wrong?' kind of questions
Will also prevent you from burning up several controllers and/or motors and/or battery:
E-flight primer and tools
And pleasepleaseplease, do your RC equipment, wallet, ego, battery, controller, motor, house/garage/car a big favour ... get a watt-meter.
It will more than pay for itself, will save you at least one fried motor and one fried controller. Will also help you finding the best setup and help you troubleshooting. A must have.
Prettig weekend Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
• E-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC •
