spe 26cc or mld 28 prop hub?
Hello, got a giles 202 with spe 26cc that runs perfect but the prop hub is split. I think the mld and spe are the same? Where Can i purchase one of these and a wood ruff key? . Really want to fly this thing. Thanks Nick
RE: spe 26cc or mld 28 prop hub?
From what I know , they never corrected the issue so replacements will crack too.... eventually.
www.cermark.com/products/Prop-Hub-for-SPE%252d26-%26-MLD%252d28,-MAP%3A-$20.00.html
www.cermark.com/products/Woodfuff-Key-for-SPE%252d26%2C-MAP%3A-%242.00.html
Thank you for info flyinwalenda, I see they have Stop ring or Front crankcase ring for SPE-26 & MLD-28, MAP: $3.00. would this be a fix so the hub cant go on crank as far and split. Have had nitros for years but this is first Gasser. also do you order from cermark? again thanks for the help. Nick
