Need help understanding a TC5 setup Sheet
QC, CANADA
Hello,
I just bought a used TC5, and I need a little guidance on how to set it up correctly. I have downloaded Keven Hebert’s setup sheet, but there are some things I just don’t understand.
Aligment :
Rear Hub Toe shows « 0 » for the rear. And Toe (total) shows 3 for the rear. Not sure exactly what it means, I think it should be negative 3, right? And what does the « 0 » means for rear hub toe?
Also, I don’t know what to check-adjust to get 2mm bumpsteer.
Suspension geometry :
I am not sure what the FWD and RWD mount shims means. And not sure what is the meaning of « 2mm up travel » in the notes .
Shocks:
In the notes, Keven mentions that there are air bleeder holes drilled in the caps. How do we do this?
The rest, I pretty much figured out…
Thank you for any help you can provide!
http://www.petitrc.com/reglages/asso...rt_IIC2009.pdf
Aligment :
Shocks:
