Engine is over heating
HI
I had recently baught a B44 and just wanted it to go extremely fast so I purchased the Momba 9000kv motor. I am running with the mommba pro ESC (I think that is what it is). Well I had put it in with the stock spur gear 84T and started off big 19T pinion obviously that was to big. Well I have worked my way down to a 14T pinion and it still over heats. The wire and motor get extremely hot with in a couple runs up and down the road. Well I took it a step further and tried a bunch of different programming on the ESC but still same out come. I didnt want to spend any more money and had a Novak 8.5 motor sitting around so I just put that in there.
I dont want to get rid of the Momba and will eventually put it in something but does anyone know why or how to run this motor with out over heating. If not I think Im just going to put it in a 1/10 drag that way im only doing short runs at a time and i wont have to worry about the heat as much.</p>
RE: Engine is over heating
The 9000 is best used in touring cars with smaller wheels (less rotating mass) with light chassis. If you may, try to fit a heat-sink. Otherwise, gearing down is all you may do. Try a larger spur gear, too.
that will go well in your tc4 (i think you have) if your want to use that in a b44, you have to gear it lower and find a biggest fitting spur gear.
HI
Yeh i was going to go up in spur but it seems to me the more gearing change i do the motor wont go as fast as i want it to.
As for the TC4 my roommate has one as well I was going to buy that off of him and use it on it. But my novak 8.5 is already extremely fast enough for me on my TC.
what exactly is crazy fast for you? Anything over 50mph is unusebale on anything but smooth paved surfaces. You will end up breaking parts like no tommorow if you are going over 50mph offroad. I think you should get the cc sidewinder sport with the 4 pole 5700kv motor.
http://www3.towerhobbies.com/cgi-bin...LXBBMF&P=0</p>
Banned
MA
Caslte Creations and Integy both sell heatsink/ fan combo kits. They both run around $13 dollars, and they both plug into the receiver port labeled BATTERY. Check to see if your ESC has a battery eliminator circuit (BEC), so that you don't need a receiver pack to run the fan.
