Looking for a good micro retract servo
I'm looking for a good servo (micro?) to use on a HOB 1/12 P-51. I'm installing the Robart #123 micro retracts. Do I even need to use a micro servo?
I've seen references to the Hitec HS75BB retract servo, but I'm afraid it might not fit on the plane with 4 other micro servos.
Thanks.
Thanks.
RE: Looking for a good micro retract servo
Specifications
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.17sec/60 degrees at no load
Operating Speed (6.0V): 0.14sec/60 degrees at no load
Stall Torque (4.8V): 15.27 oz/in. (1.1kg.cm)
Stall Torque (6.0V): 18.05 oz/in. (1.3kg.cm)
Operating Angle: 40 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 5.4mA/idle and 150mA no load operating
Current Drain (6.0V): 5.5mA/idle and 180mA no load operating
Dead Band Width: 8usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Direct Drive
Bearing Type: None, outer case serves as bearing
Gear Type: All Nylon
Connector Wire Length: 6.29" (160mm)
Dimensions: 0.89" x 0.45"x 0.94" (22.8 x 11.6 x 24mm)
Weight: 0.28oz (8g)
