Hobbywing EZRUN WP-SC8 - problem
Hi!
I have a problem with my Hobbywying ESC .
Last time I was out with my Traxxas Slash it slowed down and I could only drive at 30% throttle and after a few seconds it stopped. I restarted the ESC and it worked fine for a few seconds until it happened again.
The green light is blinking indication overheat acc to the manual but this can`t be the case since this will happen directly on start even if the truck has been sitting on the shelf for a few days. The ESC has worked fine in the truck for a long time and then all of a sudden this problem has happened. I have tested several different batteries and no change.
Any ideas?
Thanks!
Any ideas?
Thanks!
