why hex screws?
why hex screws?
Everytime I work on my car, I get a bit frustrated with the screws, They are black, hex screws, and strip out very easily. There is a good %40 chance that a screw will strip when I remove it, even if I push down hard and be very careful. If it's threadlocked, it's not coming out witthout a dremel... Now I have maybe 5-6 stripped screws, and when I need to take them out I will have to make cuts in the chassis. So, what I was wondering, is are there any advantages to using hex screws over phips or some other? I mean, to me, a hexagon is way to close to a circle to be any good, even if very hard material is used.
Hubert
Hubert
The trick to using hex screws is to have a real good driver. If you're using the L wrenches that came with a car, you're causing your own grief. For me hex is far superior to philips. Some screws are soft too which doesn't help.
I'm using a good quality set, with hardened tips, or atleast that's what the box and price told me. It might be the screws, possible they are really soft. Next time I go to the hardware store, I will see if they have any 3mm screws.
Hubert
Hubert
+1. Having a good set of hex keys is paramount. If you use Allen keys from a big box store, throw them out and get a good set of hex drivers. They do cost a bit, but are worth the money. The big box store type wrenches are often undersized a little bit which allows the bit to twist slightly and thus deforms the head of the screw. Each time the screw is removed, it gets distorted more and more until the head strips completely. Something else worth noting - the hex drivers with the ball tip tend to muck screw heads up a lot quicker than the hex keys that don't have the ball tip.
Yeah, as I already mentioned I am using a good quality set. I usually use the hex tip, but now started to use the "star tip", as the screws strip less with this one. Of course, I make sure that Im using the correct size.
The only hex screws I have trouble with, are on a redcat, which probably explains the screw quality....On my more expensive airplanes, I never have a problem with them.
Big Alice, why do you find them superior? They sometimes work for me, but on the other hand, hex screws are the only ones that I have problems with.
Hubert
Hubert
I've just always had better luck not stripping hex where philips get worn out and sloppy fitting after being screwed in and out a few times. Torks are better than hex or philips imo.
The worst ones are the tiny ones on the throttle linkage and a few other places. I just got a new throttle linkage today, and 2 of the 4 little screws are already stripped. To me, even making a hex screw of that size is against logic...
I am sure that my redcat has some really bad screws. They have some slop to, so I may be using a driver that is a bit off, but I have ALOT of other cheap ones, and none of them are perfect. Will try some other set soon. I will go to the hardware store and see if they have any 3mm screw (VERY doubtful). Otherwise I will look for some sets online. Will probably need a new chassis too, because there are a bunch of screws that are flush with the chassis that are stripped, so the dremel will unfortunately make cuts not only in the screws.
Hubert
Hubert
There's a lot of ways to get a stripped screw that's flush out without dremeling. Sometimes you can drill the head off. I've epoxied a cheap L wrench in it and had that work. A square easyout can be shortened till it can be tapped in the hole. There's a lot of ways to try before you dremel up your chassis. That's just a couple. You just have to get creative.
I keep an inventory of screws, all hex. At any sign of problems the screw gets replaced. The L-shaped wrenchs are soft and will fail.
Torx are the best, however expensive. For removal of rounded hex screws, invest in a set of small, square ez-outs. The twist type of
ez-out is for larger bolts.
My Feedback: (18)
I have found ball drivers to be the source of many problems related to stripped hex heads. Although they are handy for some applications, the cantact area of the head and the wrench is much smaller than a proper fitting standard wrench.. Avoid ball drivers unless absolutely necessary.
Use only high quality wrenches for everyday use and be prepared to replace the tips or wrenches as they wear out. I much prefer wrenches with replaceable tips.
