dragonfly simulator
dragonfly simulator
I bought a Feda dragonfly helicopter with a "zhen hua" 4 channel pcm transmitter. The transmitter is set up in mode 1. Does anyone know who sells a simulator to fit this transmitter that can work off xp operating system? Is it possible to change the transmitter to mode2?
NC
RE: dragonfly simulator
It's easy to fix the modes. Just take off the back plate. Then swap the wires for the elevator/throt down on the board. They just un-plug. Next move the tenstion arm from the throtte and move it to the elevator side to keep the stick centered. That's it!!! I would say the hardest part is swaping the tension spring. A good set of needle nose pliers is a must.
