radioa ? for newbie
RE: radioa ? for newbie
Check out the JR XS3. I run 4 vehicles with it and it can run up to 6 vehicles, each vehicle having its own settings. The set-up is also crystaless and if you go FM, that will give you about 30 different frequency channels to pick and choose from. Note that the RS300 3-channel reciver is slightly larger that some of the other 2-channel receivers; however, I've also dialed into other 2-channel JR FM recievers with the same radio if you are short on space. I have a RS300 is in my 1/4 scale, mbX5, T-Maxx, & Yokomo.
http://www.rccaraction.com/rc/articles/jr_xs3.asp
