Removing broken flybar on mini dragonfly
I snapped my fly bar today, and I'm not sure how to remove it to install a new one. Could someone run me through the process?
RE: Removing broken flybar on mini dragonfly
first pop the two outer ball links off the main blaides and the fly bar......pull on the main blades and the top part of the head. It will pop off the bearings. Then take a hex key and loosen the two screws that you are now able to get too.
