Picco 61 rear exhaust
I need a little help --- I need an exhaust header for a Picco 61. It can be in virtually any condition, What I need is the fitting that mates to the exhaust port on the engine. I can weld aluminum, so I can make up the rest of it if I can find a header that I can at least salvage the engine end from. Thanks for your help
Spud8939
Spud8939
RE: Picco 61 rear exhaust
Sam:
If you have alu. welding capability there's no problem. Cut the flange from 3/16" or 1/4" sheet and weld the head pipe to it.
Can't find the pipe? My favorite source is a cheap folding chair from Wally World. Not only do you get a good amount of straight pipe, you get several nice corners already bent for you.
Bill.
Bill.
