TLT-1 Center diff - JB weld?
ON, CANADA
Could please somebody give some instructions ( maybe with pictures ) about how to do this?
I would like to lock my center diff - but I do not want to destroy something in the process.
So step-by-step instructions ( for a total newbie ) would be very welcome...
Thank you all!
Thank you all!
My Feedback: (18)
RE: TLT-1 Center diff - JB weld?
Have you got the diff built?
If so, take a look at it and you'll see something thats like a little moat on each side of the diff (hard to explain, but if I remember correctly its about 1/4" deep and 1/4" wide).
What I did was fill that little "moat" all the way to the top with epoxy, let it cure, then I did it to the other side of the diff.
JB weld would work too, but I was in a hurry and the JB weld I have says it takes 4-6 hours to set up, so I used 5 minute epoxy instead.
ON, CANADA
jakjr, madman 3000 thank you for the advice.
My TLT-1 is in the mail from TowerHobbies - and I wanted to make sure, that I will do everything 100% right when it gets here.
First I want to build it as stock ( only difference from 100% stock: locked center diff and ball bearings) and later I will consider various mods ( Pede tranny etc.)
Since I have no real kit building experience ( I have built a couple years ago a Piccolo helicopter and a Kyosho Sandmaster ) I try to learn as much as I can before I start building it...
