A Clod Crawler "The WIDDLER" As Seen On TV!
Well here it is...... "THE WIDDLER"
My thinking when building this Rig was really focused on Three things: High Clearance, Low COG, and...... "The Stick"( It's the Machine to Beat Right?). While thinking about the "Stick" I concluded that one of it's strongest points is it's Inherent Narrowness(giving it even less to get hung up on), so I did every thing I could to keep "The Widdler" Narrow and ended up with 2 1/2" for a Chassis width(just enough to fit the ESC and Receiver between the Chassis rails). The COG ended up Awesome, it will sit on it's Side 90*(Two Wheels) without falling over on it's lid, even with a 14 Volt setup(Two Large Batterys strapped on top of the links). Clearance is Pretty good at 6 inches(under the Skid Plate), and I figured out that I could get way more clearance from the rear motor by making the Rear-Upper Links a Hair longer (With a Small sacrifice in Steering of course :roll: ). It Seems to be pretty Darn Tough so far, it's been through a little torture!
Some Specs
16" wheelbase
15" wheeltrack(outside tire)
7 3/4" overall height(top of Shock Mounts)
6" underbelly/skidplate
8 1/2" chassis length
2 1/2" chassis width
*Chassis Construction:
Aluminum Stock- 1/8" x 3/4"x 3/4 L Angle(Main Chassis Rails), 1/8" x 1" Flat(Shock Towers), 1/4" x 049 Round Tubing(Links and Chassis Braces).
Steel ALLTHREAD- 6-32, 4-40
Nuts & Bolts- 6-32, 4-40
Traxxas Rod ends Package #1942(one package is just right for 1 Complete Chassis)
Duratrax Body Mounts
**Running Gear:
Clod Axles w/JB Welded Diffs
G-Made Upper Link Mounts(NICE!)
55T Lathe Motors 13/10 Pinions
2 1/4" Shocks x4
HiTec 645 servos with custom 1/8" Aluminum Servo Mounts & Kimbrough Savers x2
Aluminum Front Hubs
1" Narrowed(Off the Insides) Outback Wheels w/Siped Moabs 8 ounces of weight in each of the Front and 2 ounces in each of the Rear(Lead wire Glued to the Wheels with CA).
***Tools
HackSaw
Drill
Course Sandpaper
Screwdrivers
Wrenches
Pliers
Tape Measure
Widdler in Action VIDEO http://www.rcpics.net/view_single.php?medid=58635
Notice the Extra Clearance from longer Upper Links on the Rear Motor(Left)
Poser Articulation Shot!
Here is a "Basic Materials" Pic (Needless to say, Pretty Inexpensive Stuff)
Some Specs
16" wheelbase
**Running Gear:
2 1/4" Shocks x4
Aluminum Front Hubs
***Tools
HackSaw
Drill
Course Sandpaper
Screwdrivers
Wrenches
Pliers
Tape Measure
RE: A Clod Crawler "The WIDDLER" As Seen On TV!
nice truck daveyboy2oo1
i was wondering how long are your links, and how far apart are they mounted on your chassis?
also thats a nice truck body, the x factor body nrver look better!
great job!
great job!
