Spektrum: Reciever light/servos
THis is my first car build and radio install. I bought a Spektrum Rx and Tx. I seem to be able to go through the binding process if I don't have the servo's connected, but once I connect the servos the Rx light stops blinking. Since its easier to work on outside the car, I want to try it out on my table before I install it. Ive tried making the connection both ways, and in different order and it does the same thing. [>:] What am I missing?
My Feedback: (33)
RE: Spektrum: Reciever light/servos
First make sure you are not putting the servo leads in backwards. With the servos plugged in turn the power on to the reciever and then turn the radio on . Wait about 5 seconds , if still not lit turn the radio off and then back on . I had the same problem with my first DX3 . You can email me if you have any questions. [email protected]
