Exceed 50 head assembly measurements
Greetings.
It seem crashing is a big part of flying helis! My question is what are the measurements for the ball link connectors on the head assembly of a Exceed rc eagle 50. I tried to set it up the same as the original, but this does not seem to be correct. There are two numbers I need the distence for the two small ball joints, and the distence for the ball joint and clevis. I am useing 16mm and 34 mm resprectivly now .but again this does not seem to be correct.
