Chevy King
Chevy King
Here is my Chevy King streched to a 12.5 wb,custom 14'' aluminum chassis,peak racing 15x2 motor reverse mounted,dynamite 15t esc.,96/15 gearing,3000 mah bat.I use a hand wound 55x1 for crawling.
My Feedback: (10)
RE: Chevy King
hi
very nice i am doing a wheely king converison they said you should turn the front wheels around so the tread is back wards so you have more climbing power here the link ,rye
http://www.hpiracing.com/news/2007061801.html
RE: Chevy King
Thank You.Yeah that work's good turning the stock tires around but i have a set of moab's on pede wheels for the rocks ,i run the stock tires for the grass and mud.
RE: Chevy King
Yeah I have the stock wk tranny never had a problem with it and iv'e been running it hard since feb.From 10 below zero to 95 above.I don't have any problems with high cg due to the way my motor is mounted and i put my bat on the front links.I have moab's but there on my stampede right now.The chassis accepts all the stock mounting lacations motor,servo,link's tranny hole's so it was a direct drop in.I could build up another chassis if someone wanted to buy one.
