Traxxas Hardened steel motor screws stripped.
ON, CANADA
How do i go about getting these motor screws out?, ive tryed but with no success, these screws hold in a Vxl motor, ive stripped my spur gear, and what to try diffrent gearing but cant at the moment,
RE: Traxxas Hardened steel motor screws stripped.
when i got my slash i took off the spur cover to check to see if the motor was nice and tight . when i seen the flat motor bolts i said to my self man if i striped one it would be a pain to get it off so i switch to the common ones the had a head so if i striped one i could use my needle nose vice grip to get it to move
I just went through this on my Slash, as yakfish said cut a slot into the head of the screw with a dremel, then use a flathead screwdriver to take it out. It works great.
