Need Help With Hpi Stalling
I have An Hpi rtr rs4 about 3 years old And When i brake the car stalls out all the time can someone help me with the adjusmnent or tell me whats wrong
RE: Need Help With Hpi Stalling
sounds like you need to adjust the idle screw
take you air filter off and look down the hole you should see a cylinder and a tiny gap
make that gap 1mm(I usually have to go 1.5) and tighten the screw so the gap won't go under that when the brake is applied.
Try it out. If it still dies make the gap a tiny bit bigger
lock tight the screw (with blue lock tight) so it don't come loose and back out once you get it set.
