HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
exicted about new TVPs
Old 11-04-2007, 05:46 PM
ravenlunatic
Default RE: exicted about new TVPs
ORIGINAL: osuwins
hey ravenlunatic, i was never able to get the sav.25 to wheelie, and the rollbar thanks,the back end was just to exposed, ive landed on the head before bent a fin and brook my engine block so im all about protecting my investment if there not,. thanks, oh yea im useing the same body but i have a proline ford 150 body im working on
i hear ya on the protecting your investments. i too have bent a cooling fin. i think i'm going to use a larger body for the sake of a better fit. im thinking the lst, mgt size bodies would look better on the extended chasis, what do you think?
Old 11-04-2007, 11:27 PM
osuwins
osuwins's Avatar
good question ravenlunatic, i would take your truck with you and try it on for size, im not ready to buy a body yet, but i never thought about the opptions, i have an f150 im working on, its an osu theam, ive done some tweeking, added 30,000 weight to the diffs,got steel dogbones for the back for now , water proofed, i put the rx box on the side thanks to the idea from azzmanm his ride is nice, well this is what my ride finally looks like, ill run it tomorrow, and i can wait
ID:	797287   Click image for larger version
ID:	797288   Click image for larger version
ID:	797289   Click image for larger version
ID:	797290   Click image for larger version
ID:	797291   Click image for larger version
ID:	797292   Click image for larger version
ID:	797293   Click image for larger version
Old 11-06-2007, 08:45 AM
osuwins
osuwins's Avatar
heres some pic. with the stock body, and blazer, i had to make some new holes but it works,my test run went great some carnege due to the fail safe glitch wile airborn, it applyed the breaks when i went off a jump at 15 feet in the air, it went end over end and landed upside down ass first on the right side[:@], damage is ---- right wheel hub where tie rod mounts brook, i just switched it out with the left one, rear rool bar cracked,header pipe bent, rear right shock mount screw bent, was able to fix everthing and finish bashing,, love this new mod
ID:	798127   Click image for larger version
ID:	798128   Click image for larger version
ID:	798129   Click image for larger version
ID:	798130   Click image for larger version
ID:	798131   Click image for larger version
ID:	798132   Click image for larger version
ID:	798133   Click image for larger version
Old 11-06-2007, 11:50 AM
ravenlunatic
wow. that looks painful.
Old 11-06-2007, 07:44 PM
dhyde79
I dropped a set of RC Solutions X Lightning (black) TVP's on my old savage 25 (and the radio box and transmission case from an X) and love them to death....though.....they actually made my truck TALLER instead of dropping it down.....my new era roll cage wouldn't reach the mounting holes for the transmission so I put the stock roll bar on, and drilled a pair of holes through for the new era cage to mount to, and am using the gap between the roll bars to run my back pressure line with a steel coil cover over the fuel line.
made enough of a height difference that in order to mount the dodge body on the truck I had to use the taller rear body mount on the front (short one still fit fine in the back)
will post pics in a few once I get them pulled from the camera and uploaded.
