Alm Meca Turbines
Alm Meca Turbines
Old 11-19-2022, 04:47 PM
  #51
FenderBean
FenderBean's Avatar
You are basing your comparison off of things that don't match, fuel consumption listed is not max RPM for the motor so yes it will be lower for one. Your 180 is bigger and heavier than all compared 180s and until it shows max rpm fuel burn people will assume it burns more, the 26,000 extra RPM will increase fuel consumption substantially. New gen motors will have brushless starters, brushless pumps, ECUs on the motor, internal sensors and valve, bus type protocol and digital vs analog.
FYI your motor is listed with a XICOY V10 ECU, which is no longer produced and outdated. Specifications have nothing to do with the quality and technology used to produce them so don't confuse that when talking about old vs new.
Cheers, good luck
Old 11-19-2022, 05:09 PM
  #52
peter 098
Cheers, good luck
Actually you are incorrect, the size of this engine is not the largest in the class. It is actually in the middle as for size (diameter being in the middle, the length being the longest but you also have to take into consideration of the exhaust cone) and for the weight of the engine it includes the weight of everything, engine+control box. Some brands don’t state wether it’s included in all up weight. And to look at the consumption I have asked to do tests at max rpm so we will see. But like i said before if you look at the comparison with all the other stuff it shows that this engine can hold its own in many of the categories especially the 210. But thanks for your comment it’s appreciated.
Old 11-19-2022, 05:34 PM
  #53
FenderBean
FenderBean's Avatar
Size is more than just diameter, when you compare width, length and weight, I am correct with my comment. Comparing 180/210 motors to anything other than 180 and 210 thrust isn't comparable at all.
Old 11-19-2022, 05:45 PM
  #54
peter 098
Well not sure why we aren’t on the same page, all of the engines are pretty much in the 180/210 range (+-10N) Which is a pretty good comparison. As for the engine weights the ecu box added another 300g which means the 210 is at 1800g and the 180 is at 1700g which is still pretty good.
Old 11-19-2022, 05:48 PM
  #55
peter 098
Here is a comparison between a k-160 g2 and the A-180. This is just so you guys can get an idea at how large it is since most of you probably have see a k-160 and have a general idea at how large it is. Also this is the only other engine I currently have on the bench.
Old 11-20-2022, 11:07 AM
  #56
highhorse
highhorse's Avatar
Originally Posted by peter 098
Can you please explain to me about I was “Dodge” on Fbook even more on this group? Someone asked a question and I asked them to please refer to my more recent posts, nothing dodge about that just seems like laziness on your part because you could hav exist clicked on my name and seen more about the turbine. The two secound response was a spec on the engine but since has been bounced up to 3 sec. Nothing fishy that’s how it was.
The dodge was as follows: You made a vague claim on your FB page that the specs of your brand are better than all others. I asked WHAT was better than all others, and you referred me to the publishes specs which are clearly NOT better than all others. They aren’t even better than most others. They are only better than two others which are very old designs.
You dodged the question rather than directly answering it, presumably because you knew the your claims are out right FALSE.
Dude, I get it. You want to make some coin and maybe even be a player in the turbine supply business. Your problem though is that you are dealing with sophisticated buyers who see right through sophomoric sales tactics which are setting you back by laying waste to any shred of credibility you might have otherwise had.
Old 11-20-2022, 11:23 AM
  #57
highhorse
highhorse's Avatar
Other brands also update their turbines many times over the years after they have been released. Guess that isn’t wise on their part either.
Peter, you’re grasping at more completely illogical straws here and I am begging you to stop doubling down out of desperation. It only harms your cause. Perhaps you are still, all evidence to the contrary, operating on the hopes that your potential customers are uninformed?
The other name brands updated as a result of innovation, in order to keep up with each other in a competitive market place. If they hadn’t kept up then they would have died. This new brand is STARTING OUT two generations behind and costs more to boot. There’s simply no compelling reason to buy into the brand here.
Compare that to another recent new brand -Xicoy- which actually started out at or near the cutting edge and has been competitively priced from the outset. Or to the Kingtech launch which was not cutting edge but made up for that disadvantage through lower pricing. The key there is that the rep didn’t’ ruin KT’s reputation with absurd claims.
Old 11-20-2022, 11:54 AM
  #58
highhorse
highhorse's Avatar
Hey guys, so I did some investigating to see what the specs are for all the major turbines on the U.S market for the 210 size turbines(some brands have a bit larger or a bit smaller but more or less around the 210 mark) and I got to say the a-210 is a real competitor comparing to all the normal specs that the turbine mfrs have on there websites. Starting off with price, it is very competitive considering some brands are asking over $4000 for less powered turbines but we aren’t here to judge. A-210 has the smallest diameter at 109mm followed by jc-200 at 111mm. It does have the longest length at 330mm but this includes the cone at the end not the actual can, again some brands don’t have it even specified. Has the smallest amount of consumption rate at 450ml/min at 100k rpm, some companies, as you can see below don’t, don’t even mention at what rpm but alm meca has that specified. All around the 21kg mark since they are all around the 210n mark. Is the the second most heaviest followed by the p-200 but again some companies don’t specify complete weight. On the high end has the highest rpm out of all the other engines at 124k, and has a 3.5sec acceleration from 33k-124k, again some of the companies don’t have times specified(almost none actually) and has almost the lowest idle rpm at 33k, Jc-200 at 32k.
So to come to a conclusion, the A-210 is like I stated above very competitive in the 210n market. Also has some key specs specified even with other brands not having anything you guys have mentioned like 5000ft tests. Some brands don’t even have some basic specs specified. Soon I will be making comparisons for the A-180. So all in all most of you guys made this turbine seem like it’s an ancient artifact that doesn’t have any specs but like I have proven has many key features that beat some of the other larger brands on the market. All of these came directly from the companies websites not making any of this stuff up.
Alm meca A-210
$3250
Diameter: 109mm
Length: 330mm
Consumption/min: 450 ml/min at 100,000 rpm
Thrust 210 nm = 21KG
Complete weight = 2.1 KG (turbines + control box) 2100grams
Temperature (Celsius): 550/750°
Fuels: Kerosene, Diesel, Jet 1A
Materials: Aluminum, steel, stainless steel
RPM Speeds: 33,000/ 124,000 in 3.5sec
Kingtech K-210
$3150
Diameter: 112.6 mm
Length: 280 mm
Weight: 1740g
RPM Range: up to 33,000-120,000RPM
Thrust: 21 kg @ max RPM ( 46.3 lbs at max RPM)
EGT: 650°C max
Fuel consumption: 590 g / min ( 20.8 oz / min ) 615ml/min
Swinwin sw-220
$2950
Thrust
22 kg / 47.5 lb
RPM Range
35,000 r/min ~ 110,000 r/min
Rated Exhaust Temperature
750℃ / 750~1382℉
Fuel Consumption
16 oz/min @ 90% Power 110,000 RPM(473ml/min)
Fuel
Kerosene, Jet A or diesel
Lubrication
5% kerosene, Jet A or 3% diesel
Start
Full auto-start
Restart
Auto-restart
Weight
1700 g / 60 oz / 3.75 lbs
Diameter
116mm / 4.57 in
Length
280mm / 11.02 in
Maintenance Interval
Every 25 hours
ECU Supply
3 cell li-po
Total Weight
2000 g / 70.5 oz / 4.4 lbs
Behotech jb-220
$4150
Diameter
113 mm – 4,45inch
Length
313 mm – 12,32inch
Weight
1640g – 3,62lbs
max. thrust
220N – 49,46lbs @ 123,000 rpm
min. thrust
8,05N – 1,7~1,81lbs @ 35,000 rpm
Fuel consumption @max. thrust
arround 720 ml/min
Exhaust gas temperature@ max. thrust
arround 750°
Fuel
Diesel or Jet A1 (+5% turbine oil)
Acceleration 35.000 – 120.000 rpm
4 seconds aprox.
Acceleration 60.000 – 120.000 rpm
1 second aprox
Jet central rhino 200
$3450
200 Newtons (45 Lbs) @ 121,000 RPM
Idle Thrust
6 Newtons (1.34 Lbs) @ 32,000 RPM
RPM Range
32,000 – 121,000
Weight
1.78 Kg (3.93 Lbs)
Diameter
111.0 mm (4.37”)
Length
302 mm (11.89”)
Exhaust Gas Temperature
500ş C – 700ş C
Fuel Consumption
0.55 Lt/min (19.5 Oz/min) @121 k 576ml/min
Jetcat p-200-Rx
$4600
Thrust: 52 lbs @ 112,000 RPM
Weight: 5.53 lb (2510g)
Diameter: 5.12 inches (130 mm)
RPM Range: 33,000 – 112,000 RPM
Exhaust gas temp.: MAX 750°C
Fuel consumption: 25 oz per/min at full power
Fuel: Jet A1, 1-K kerosene
Lubrication: approximately 5% synthetic Oil in the fuel
Maintenance interval: 25 hours
I notice first that you make no such claims for the 180. Good for you, as it’s indefensible.
Some pretty serious cherry picking with the 210 though, and I quit reading after your latest absurd “selling point” that only your brand lists a fuel flow at a completely arbitrary 100k rpm. Seriously? If 100k rpm is somehow relevant then tell us what the 100k thrust is and compare your fuel flow to motors in THAT class. Don’t blow smoke up our skirts by trying to compare apples to oranges.
Your 100k is more red-herring nonsense, of course, designed to mask the fact that you do NOT list the industry-standard fuel flow at max rated power. Why do you keep doing this? Why do you keep hoping that your non-answers, and slights of hand are going to sell engines?
CHALLENGE: Peter, please tell me exactly which 210-class (200-220) engine(s) your brand beats in terms of installed weight and fuel flow at max power, while costing the same or less. AND give us those numbers based upon the incoming proprietary ECU vs the tried and tested Xicoy ECU which is currently sold with your engines but is to be displaced in future units.
Old 11-20-2022, 12:09 PM
  #59
highhorse
highhorse's Avatar
Gaslight, much? No Peter. Your audience is not stupid enough to let you lump 180’s and 210’s into the same class.
More credibility lost. I am begging you for your own sake. Please stop.
Just. Please. Stop.
I have only read through the first of three page of this thread and have already found too many falsehoods and misdirections to count.
I give up for now but you can count on my return if/when RCJI publishes a test of the 210. I look forward then to comparing your numbers to tests from 10-15 years ago.
Old 11-20-2022, 12:29 PM
  #60
peter 098
I am sorry but I think you are getting wrong. these turbines are very competitive with all the other brands. I’m not making up any of my specs or the specs of the other brand engines, that’s what they have posted and that’s what I’m basing my research off of. Can you explain what old design I was comparing with? The kingtechs where the all new g4+, the swinwins where all the newest and latest and greatest, the jetcat I guess was the only “old design” engine on the list. For the no uat, you can take it or not, I personally ran NO UAT with the felt clunk and didn’t have any problems as for the guys in France. No issues, no flameouts, NO ISSUES. Maybe I and all the guys in France got lucky I guess even with more complex fuel systems, that’s how it is. It is in the turbines manual stated that no uat is required. Not sure what they have changed to be able to cause this as i am not in France and not able to see what new system they incorporated.
Old 11-20-2022, 12:33 PM
  #61
peter 098
Again, I do not understand your comments? Did you look at the data of the other engines? Did you see that most engines were pretty much at that price or higher? Again I am going to say it; According to all the data given by all the other larger brands on the market the Alm-meca turbines have pretty much the same(or better) specs, this is all according to what the brands have posted and what the Alm meca turbine specs have, nothing is made up these are specs, I know it might be a bit hard to get over your heart but numbers don’t lie. That’s how it is.
Old 11-20-2022, 12:49 PM
  #62
peter 098
I am not comparing apples to oranges, I am trying to use the specs that all the other brands have posted.
Alm at least listed a power setting, what power setting it was tested at, some of the other brands don’t even have it posted at all or at what rpm. Including what some may argue two of the largest brands kingtech or jetcat.
It beats from what I can see jetcat in weight and is pretty much tied with jet central, two very large brands. It beats all for can size. Most of the other brands don’t state what they are actually weighing, if it’s just the can, or if it included the ecu and pump also. Or if the wires also are included in all up weight. ALM-meca states that but you would have seen that if you went threw the data. For max power fuel flow I am unable to answer that because many brands don’t stare at what rpm they are testing and getting their data from. And price wise it beats all the brands except for the kingtechs and swinwin’s. Again nothing made up I am just going off of what mfrs have posted.
Old 11-20-2022, 12:56 PM
  #63
peter 098
Not sure where you’re getting me lumping 180’s and 210’s together? Haha, do you know how to read?
Just. Please. Stop.
please explain where? These engines compete with the other brands on the market? If you were to look at the data which you obviously didn’t you would see no lying going on. That no UAT is required? Welp, like I stated above I do not run a uat and so does no one in France where these engines area made, as you could tell in the video no uat in my airplane period. That these engines are actually reasonably priced compared to the market? It is. Again look at the data, if you would have read you would have seen it. So not sure where you are getting this from?
Again I used all the data from all the engine brands currently out there, not from 10-15 years ago. K-210g4+ where not made 10-15years ago neither sw220 neither the xicoys so this just shows again you didn’t actually read it completely which proves to me even more that 1) you don’t know how to read or 2) comprehend. Thanks
Old 11-20-2022, 01:21 PM
  #64
peter 098
In conclusion Mr Highhorse; Please make sure to read everything. Stating that these engines are ridiculously overpriced or that engines being made to order is an issue, or that I have no experience, or that I am dodge becuase I asked to you look at some of my recent posts or that I am comparing engines from 10-15 years ago or that these engines are relics or that this engine has no specs like all the other brands out there or that this engine can’t run a UAT, that’s impossible, even though there is video evidence, or what ever outlandish and false claims you have. Next time please take some time and look around so you understand what this or any other engine is competing against on current markets. And please when you are trying to insult me please use actual data and not made up things that came from your made up fairy land, I used all stated specs and facts that other brands have on websites when making my comparisons and it’s not my fault that some brands don’t have some key specs stated. Use real facts. I will not be answers to anymore of your ridiculous claims and comments because you have proven to me that you have no idea what you are talking about and even less experience and from what I can tell from all your other posts you are just another troll/keyboard warrior that loves to waist other people’s time. Thank you and enjoy your Sunday like I am.
Old 11-20-2022, 01:57 PM
  #65
Dansy
My Feedback: (53)
Dansy's Avatar
It’s pretty obvious your missing the point completely, the motor your trying to sell is a pretty old design and used old Xicoy V10 ECU with Old GSU that even Xicoy doesn’t use on there motors, the trend is lighter smaller more power for the size, nothing your motor have..
I have no bone in this I don’t sell anything and I’m not sponsor by anyone, I do understand your position, you probably taught it would be easy, when you compare the K210 that motor has been out for quite a while, but is constantly refresh it has touch screen GSU, and now with brushless starter and pump, new ECU, DRM, all the Kingtech are now working on a BUS system……..
A yet your motor are more expensive then most, plus It need to be sent back before the 2 years mark…or the warranty is out, really….I guess you expect your customer to own only one motor….outer wise 50 hrs take time…shipping to France and 300 per 2 years it’s…..not the norm.
‘I think all major manufacturers of micro jet motor, used modern technology, the $5.00 of 3D printing for front cover and pump/ECU cover is Not a plus at that price point, it look cheap and not durable….not sure what they were thinking there, make no sense to me….
It’s futile to try to compare your motors with other manufacturers, the comparaison are all modern motors, specs are only one part of the equation….
Really there’s no need to answer…..I’m just making some obvious observations.
  #66
peter 098
Originally Posted by invertmast
I see lots od opinionated “facts” from the OP on why these are great, but nothing that can substantiated outside of his personal opinion on the product.
they look nice, but outside of that, you better bring something industry leading to the table in this part of the hobby to get people to give it a look.
Compared the pretty much all turbines in same class and they are competitive based on specs with all major brands.
Old 11-20-2022, 02:06 PM
  #67
peter 098
Some I understand what you are saying, with the size to power, again this engine competes with all brands out there. With the brushless starter/fuel pump I told them that’s something they need to work on and promptly they are doing. Engine actually isnt more expensive than most, it’s very reasonably priced with all other turbines on the market at or actually a lot less then the big brands. The ecu box are going to be aluminum and the front cover is made out of very strong 3D print material not the cheap stuff that fall apart in your hand.
And for the part about specs, yes they are one part of the equation but a very large part.
Old 11-20-2022, 02:24 PM
  #68
peter 098
Ok guys I see you guys aren’t to found of the new release, I will just do some cliff notes as some keep loving to go back to it.
1) The turbines when you look at market is very reasonably priced, I don’t understand why you guys keep saying it’s ridiculously over priced? Have you guys looked at the other brands out there? I mean this is the most expensive side of the hobby, they are expensive turbines don’t get me wrong but all the turbines out there are expensive.
2) The service is a bit high but again we are talking and changes will be made. Currently it’s at 50 hours or 2year what ever comes first. It’s at about $300 for service which is reasonably priced like all other brands. But you do also have to remember that this turbine has life time warranty including everything inside the engine, bearings, shafts, wheels.
3) the 3D printed parts, the ecu box is currently as we speak being developed to be made out of aluminum. The front cover and starter motor housing is 3D printed, it is made out of very high quality material that is very durable, it’s not some cheap plastic like you get with the uat holders or what not. It’s very strong.
4) The size of turbine, everyone keeps taking about how large it is. When you look at the other brands these engines are very competitive with size and weight with all the other same n size turbines on the market.
5) Some may not talk about how for example how nice the turbine bracket is nicely done, cnc machined and not just some crappy flimsy pieces of aluminum that I can bend in my hands or every time your in a crash you have to replace because it bends and doesn’t clamp the turbine properly or when you are screwing it together.
6) State what all isn’t specified on the specs sheet even though not many(if any) other brands specify what some have asked. And then complain that there is so little about this engine specifics actually told. But other don’t specify either and have less information then what Alm meca provides.
Old 11-20-2022, 02:37 PM
  #69
sysiek
My Feedback: (176)
sysiek's Avatar
The should be list of most crappie turbine bracket , lets start with jet central jetcat and more, maybe someone will install camera inside the jet to make a video how the turbine holds up with full acceleration and some crazy g forces that some jet going through that would be a great eye opener
Skunkwrks (11-23-2022)
Old 11-21-2022, 08:48 AM
  #70
FenderBean
FenderBean's Avatar
Because the technology used is out dated, brushed motors, old ECU, external ECU and analog vs digital just to name a few and to change this is to basically change the entire motor.
This will need to be shown vs mentioned, the bearings used in these motors typically are all the same so to claim double the life is suspect but possible
Plastics get brittle with heat and age
Current NEW Generation motors of all brands are smaller, 180s are the size of older 160s, 200s are the size 180s and so on
There is a reason why clamps are flimsy, from turbines to car hoses, its to conform to the shape its going around and gives vs breaks. Not a big deal which just personal pref.
6) State what all isn’t specified on the specs sheet even though not many(if any) other brands specify what some have asked. And then complain that there is so little about this engine specifics actually told. But other don’t specify either and have less information then what Alm meca provides.[/QUOTE]
All specs can be found typically in the manual for each motor or at least what you are trying to compare
Keep in mind just a few people are on the forums and just a few of many are providing their feedback, but after being in the game for a few years now this will be what everyone provides in feedback. People spending this kind of money will always want the more current technology, people will always want more information than you have, people will always be concerned with warranty and ability for fast reliable service. A solid history of performance and CS will sell the brand better than any post on the forums. cheers!
Old 11-21-2022, 01:09 PM
  #71
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Lol I've missed the good old rcu pissing matches! It's been a long time since I've seen something like this.
Hey competition is healthy, looking at this engine personally I don't see it as competition. The consumer wallet will decide. It's old tech which I'm ok with, that said, I'd never buy this for my own reasons compared to other engines on the market but to each their own.
oh RCU, the drama lol. Where is Tracy Jensen? Surely this would be the perfect power plant for the glascat!
invertmast (11-24-2022)
Old 11-21-2022, 03:18 PM
  #72
peter 098
Keep in mind just a few people are on the forums and just a few of many are providing their feedback, but after being in the game for a few years now this will be what everyone provides in feedback. People spending this kind of money will always want the more current technology, people will always want more information than you have, people will always be concerned with warranty and ability for fast reliable service. A solid history of performance and CS will sell the brand better than any post on the forums. cheers![/QUOTE]
Ok I appreciate your message. Thanks
Old 11-23-2022, 08:37 AM
  #73
why_fly_high
My Feedback: (19)
I appreciate anyone trying to bring a new product to market. The problem I see is that there are no differentiators for this turbine. It is priced in the range of all the others. Specs don't show any advantages. The 2 year thing is an issue I think. I know there are some active guys but I would bet 90% or the turbines out there don't hit 25 hours in 2 years so the service interval is actually not an advantage and an increased cost over time. I have owned Xicoy, Kingtech, and Jet Central. There are a lot of factors that go in to buying a turbine. I can honestly say there is nothing about this turbine that would make me choose it over an established brand.
Old 11-23-2022, 02:48 PM
  #74
peter 098
Thank you for your message, and I agree the 2 year is an issue that has to be discussed and will be revised.
Old 11-23-2022, 05:23 PM
  #75
causeitflies
causeitflies's Avatar
Isn't JetCat's warranty one year from date of purchase?
Canadian Man (11-24-2022)
