Cogging???
NY
just meaure the dimensions of the battery box and then go to www.hobbkying.com and find one tat fits those dimensions
My Feedback: (12)
MO
I once had a VXL in my b4 and it cogged as well. I was using an FM tx/rx, but when i switched to 2.4ghz the problem went away. This can also cause "cogging" like symptoms.
ORIGINAL: cooldriver385
Oh, that's very true, I forgot to factor that in. I was just looking at the voltage which 2 6 cell NiMHs gives 14.4V and 2 2S in series will give you 14.8V. By the way, is there any lipos that fit in the mini Revo besides MaxAmps lipos?
2200 2s zippies I hear fit (I wanna get some eventually) you gotta cut the battery box a little for the wires.
I run 2s 1300 $6 sky llipos in mine in parallel (they HAVE to be run in parallel due to low C-rating) on a HW 35A esc with the vxl motor.
#31
Well if you run 4S won'*** kill it?
2 2s in parallel = 2S... The amperage ads up. so in my case 2 2S 1300mah 15C batteries = 2S at 2600mah with 15C(which puts it over what needed C-rating wise
in series its the opposite the voltage adds and the mah stays the same.
#33
ORIGINAL: thehuntingterminator
sorry for my inexperience, but can you put any 2 batteries together and achieve same voltage but double MAH??? And if so how???
If voltages are the same yes they will add(not multiply it seems like multiplication due to the same capacity packs). you need a parallel connector
parallel connectors basically hook positive to positive, and negative to negative.
You technically can do it with packs of different amperage, but I would advise against that as one will get taxed heavier than the other if they are not the same capacity.
If they are the same capacity they should get the load split evenly between them.
