Ziroli 1/6 Hellcat Build
#402
Well, you could order from Mirce at NS Modelers, perhaps even the full detail kit. He scaled down his Hellcat kit panel details to 1/6 to fit my build. Or, just order rivets and/or screws ala carte. Or, check with ChadV - I saw on one of his pages that he made his own at one point, similar, I think, to what Mirce does. ChadV did post some comments here, fairly recently - but I don't know what he's up to.
Someone could probably put the NS Modelers rivets on faster than me. I get into a groove and then need a break, other things need attention....but that's been my whole build!
I had a company in EU interested in completing the cockpit details for me, but they wanted a complete set of cockpit drawings - the pictures I had were insufficient for them. I haven't found a set of such documents, yet.
#403
Did you see my other comment on rivets from Mirce or checking with ChadV?
#405
Only 116 rivets left in my supply - will run out tomorrow! More on the way. I've gone through 15,196.
Rivets are completed from the nose to the 6th panel line behind the cockpit. 116 rivets will complete maybe half of the 7th panel line and the lateral lines between 6 and 7. Hopefully, the next set of rivets arrives soon as I've been on a roll. There are some odds and ends I can work on in the meantime.
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_0665_83c11c26a20f4e4b7a7078245ec1b6d99c614f84.jpg)
#406
I'm not going to do it on this plane, being that the plan is just for a 10-20 footer but they sure add a lot to the realism. Looks great!
By the way, I broke down and used chart tape for the panel lines. It was just much quicker for me than doing all of the sanding against the tape and sending the result down, so forth.
A P-47 is a real hodge podge of panel shapes!
#407
Have you seen the P-47 videos from Greg's Airplanes and Automobiles on YouTube? Here's the P-47 Playlist. He has several videos going into a lot of detail, including Bomber Command's resistance to drop tank development. After seeing all of his research, the P-51 doesn't look like the savior I was lead to believe that it was. Yes, the P-51 is still a great aircraft. But properly outfitted, the P-47 and P-38 could have led the bombers deep into Germany - because they were already covering greater distances in New Guinea in 1943. They had drop tanks in the South Pacific in 1943, because a general there took matters into his own hands and developed them with the Aussies and Ford Motor.
I always respected the P-47, but my level of respect increased dramatically after seeing Greg's research.
Maybe you've seen these already? If not, enjoy!
#409
15,312 rivets and I'm out! Next batch not received, yet. In the meantime, I realized I put the foot holds in the wrong place. I'll be drawing another set of lines in prep for moving the foot holds to their correct locations. Doh! I don't like doing things twice, but at least I didn't paint them in place. While waiting for the next batch of rivet details, there are still some screw details that I could work on placing, and I could work on improving the curvature of the air/elec. panel access cover.
I could go ahead and order the paint, too. Getting close!
G.F. Reid (07-01-2024)
