Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
ECU v12 TELEMETRY NOT WORK - FUTABA
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 01-08-2024, 04:57 AM
jarizaga
Default ECU v12 TELEMETRY NOT WORK - FUTABA
Hello
I'm having problems with telemetry, use a jetcat ECU v12 12.79 version and futaba SBUS2
On ECU select the item
TELEMADAP / INTERNAL A=1
TELEMETRY / FUTABA SBUS-2
On FUTABA select the sensor
SLOT 1
The tests I did
1) TELEMADAP / all combinations -> unsuccessfully
2) CHANGE SLOT on FUTABA -> I get some information in SLOT 8, but it is wrong (it is no correct ITEM/VALUE)
3) USE a EXTERNAL TELEMETRY ADAPTER
That worked without a problem, I received ok data on the futaba in SLOT 1
Has anyone had the same problem?
Can you help me?
Regards
Old 06-03-2024, 10:04 AM
kemp83
Hi jarizaga!
I have recently purchased the new P160Rxi-B. I tried to set up the telemetry function with the Telemetry Adapter V1-1 Art.Nr.:61108-70, with FUTABA T18SZ, unsuccessfully.
I would appreciate your consultation concerning this issue since you managed to set it up successfully. Please read below all my relevant actions:
1. I have upgraded my FUTABA T18SZ to the latest firmware version, V4.3E.
2. I registered the Telemetry Adapter V1-1 Art.Nr.:61108-70 via my FUTABA T18SZ rear sensors telemetry port.
3. I connected the Telemetry Adapter with the 8 pins cable.
4. I entered the LIMITS menu and I changed the Telemetry to FUTABA .
5. I turned off the ECU and turned it on again, but when I entered again the LIMITS menu, there was no telemetry adapter number next to the Telemetry, as indicated in the Telemetry Adapter manual and the telemetry parameters on my T18SZ are not shown.
6. I then changed the TelemAdapt. In the LIMITS menu to External, A=1, 8.4, which was then also indicated next to the Telemetry of the LIMITS menu. I then turned OFF and ON again the ECU, but still I get no telemetry parameters values on my T18SZ.
Could you please help me understand what is the problem and how to solve it?
Furthermore, concerning the V12 ECU integrated telemetry, how is it connected from the ECU to the Futaba receiver? It is not described somewhere in the manual. Do I have to register the ECU as a sensor on my futaba transmitter or just connect it directly to the receiver?
Thank you in advance for your help.
