Go Back  RCU Forums > RC Helicopters > Electric RC Helis
Charger question for the guys here
Old 04-09-2004, 02:28 PM
FlyingFish
My Feedback: (17)
Default Charger question for the guys here
I have a Tower hobbies model 420 AC/DC 6-7 cell charger. I just got a 2nd hand Corona Helicopter and it came with a couple of battery packs that are 7 cell 8.4v 3000 mAh. My question is this; Can the charger I have charge these 3000 mAh battery packs and if so, for how long should I charge them for...? Below is more info and a pic of the charger I want to use.
This is one of the lowest-priced chargers around. It is an AC/DC charger that
is perfect for the entry level setup. It safely fast charges 6- or 7-cell
batteries, then switches automatically to TRICKLE charge. Ampmeter shows
charge progress. This charger has a One-Year Warranty.
FEATURES: Safely fast-charges fully drained batteries in 20-40 minutes
Charge/Discharge switch lets the modeler make the appropriate
selection
Simple to use: set timer to 15 minutes ... built-in electronic timer
automatically switches to TRICKLE when knob is at O (zero).
AC input .8 amp fuse protected for safety (bus, glass tube type)
INCLUDES: One 6-7 cell charger w/connector that plugs into a Tamiya battery,
AC outlet plug and DC alligator clips all prewired.
One Kyosho battery adapter
One extra fuse
SPECS: Input Voltage: 110V AC US Standard
12V DC
Length: 6-3/4"
Width: 4-1/4"
Height: 2-7/16"
COMMENTS: The instructions are on the box, along with the appropriate charging
times.
7.2V 8.4V
Charge Times: 1200mAh 19 min. 29 min.
1500mAh 20 min. 37 min.
1700mAh 24 min. 41 min.
This charges at a 5 Amp rate and is NOT recommended for charging
NiMH batteries. The charge rate is not adjustable on this model.
Old 04-09-2004, 08:23 PM
mbba2002
Banned
My Feedback: (10)
Default RE: Charger question for the guys here
You can charge the batteries a 5 amp for (2 1500 mah cycles times) You should get a better charger. I have had the cheap charger and went threw them when I should have bought a good charger first and saved my money.A TEKIN 112c charger is what I have now and what I should have bought a long time ago.
Old 04-10-2004, 09:15 AM
lawnhawk
lawnhawk's Avatar
FlyingFish,
If these batteries are NiCDs, than no problem. Assuming these are not NiMH batteries than your charger will charge them. At 5 amp your looking at a little over 1/2 hour, the rule of charging is 1C for one hour, mean 1 x battery capacity = 1 hour.
So for your batteries of 3 amp hour capacity, the charge would be 3 amps for 60 minutes, or 6 amps for 30 minutes. You would be looking at a little over 1/2 hour which is a typical fast-charge rate.
Again, don't use this charger on NiMH, as the instructions say.
