reversing a servo
reversing a servo
Old 04-02-2008, 09:32 PM
pthomas1956
Default reversing a servo
hey guys i need help..... how do i reverse a jr 537 servo ??
Old 04-02-2008, 10:31 PM
vicman
My Feedback: (10)
vicman's Avatar
Default RE: reversing a servo
You should be able to do it with your transmiter.
What kind do you have?
Old 04-02-2008, 10:32 PM
TexasAirBoss
My Feedback: (22)
TexasAirBoss's Avatar
Most modern radios have servo reverse switch selections on the transmitter. Long ago, when most radios didn't have that feature. It was posible to open the servo up and reverse the wires on the pot, as its called, or potentiometer. But I'm not certain thats even possible on the modern servos.
Old 04-02-2008, 10:43 PM
Dorsal
My Feedback: (17)
Dorsal's Avatar
I believe you'd need to reverse both the potentiometer and the servo motor.
Old 04-03-2008, 04:37 AM
The Ghost
The Ghost's Avatar
You need to swap the motor wires(Black/Yellow) and you also need to swap the pot wires (Brown/Blue) or just buy a Hiteck Servo as they are reverse or JR.
On most of the lower end servos you can , but the higher end (Digital) and coreless servos it is not as they are soldered directly to the board.
Cheers
Old 04-03-2008, 05:57 AM
Dr1Driver
In the "old days" servo motors and pots were loose-wired. The servo could be easily reversed by swapping the motor wires and the outer pot wires. Now, most are hard wired to the PC board and are VERY difficult to reverse. I'd buy a commercial servo reverser or do it with the TX.
Dr.1
vicman
My Feedback: (10)
vicman's Avatar
doing it with the TX is a million times easier
Old 04-03-2008, 08:14 AM
Acs_guitars
Acs_guitars's Avatar
Depending on the purpose and linkage to the servo, you can simply move the linkage to the other side.... Also as others have said, the TX should have a reversing switch. If this is 2 servos on a Y and 1 needs reversed, get a servo seversing Y-harness and be done with it.
Old 04-03-2008, 09:22 AM
Deadeye
Deadeye's Avatar
Doesn't JR sell all there servos with a reverse option? Ie: JR 537r servo.
Old 04-03-2008, 10:08 PM
sscherin
sscherin's Avatar
Hitech Digitals can bee programed to run reversed.
All it takes is a $150 programmer
Old 04-04-2008, 07:19 AM
mikegordon10
mikegordon10's Avatar
If ya just need to reverse the direction and don't wanna or can't use the transmitter then just substitute a JR Servo for a Fubar or vissee versee. Pretty simple really.
Old 04-04-2008, 05:49 PM
cyclops2
cyclops2's Avatar
If you want the existing pushrod to stay straight. Mount the servo upside down or even sideways. No harm. Works everytime.
Old 04-07-2008, 07:54 PM
victorzamora
Ha! I didn't know Futaba and JR servos rotated in opposite directions! Learn something new every day!!
Old 04-07-2008, 10:18 PM
mikegordon10
I'm not 100% sure but I think it has to do with positive/negative shift thing.
Old 04-08-2008, 08:46 AM
Rodney
Servo direction has nothing to do with shift, simply a matter or the way the motor and feedback pot are connected inside the servo. Futaba and Hitec also rotate the opposite directions with the same change in pulsewidth.
