5g6-1 take off problems
Hi guys purchesed my first heli yday and come today, when trying to fly the first set of blades (bottom set) are not spinning, on closer inspection the motor doesnt spin, you may be thinking oh the motor has gone, but sometimes it works but 90% of the time it dosnt, could it be related to all the trim setting etc? thanks in advance for your help
RE: 5g6-1 take off problems
Always bind heli with throttle trim set to zero. If that doesn't work...swap motors to see if problem is a motor OR 4in1. Make sure to get gear mesh PERFECT !!!
Report back...we are here to serve Ted
