Run Without Air Filter Oil?
GA
What would happen if I ran a HPI Baja 5b without air filter oil? My LHS isn't getting more until next Wednesday or Thursday.
NS, CANADA
RE: Run Without Air Filter Oil?
Is it absolutely dry, or does it have some residue left in it?
All the oil does is attract small particles. The filter will still filter, but not nearly as well. If you're running on grass, it's probably fine. If in a dusty area, such as dirt or pavement, it's more risky.
You can always get that Bel-Ray air filter oil from your local motorcycle shop. That's what I'm going to use next time as I have some around for the dirtbikes. I'd do that if I were you.
At least use some motor oil or some cooking oil from your kitchen.
Yes the filter its self keeps birds and small children out, the oil takes care of the rest.
WI
In all likelihood you'll be just fine running without. The stock air filter is good at keeping dirt out. I, myself, don't get too bent out of shape if I don't oil the air filter regularly. I have had my baja for 3 years now and haven't had a dirt related issue. As with any choice like this there is always a certain amount of risk, and you just need to decide whether the risks outweigh the rewards.
My Feedback: (8)
oh air filter oil... i thought just air filter...... ok now thats not to bad at all just dont run without filter... with out oil isnt bad. you can use almost any kind of oil temporarily baby oil, motor oil, tranny fluid you dont need the actual filter oil
CT
so much BS about the expensive r/c car "air filter oil"
there isnt supposed to be such thing........
i usually dont put oil on my air filter wether its a 8hp b&s or a 3cc nitro motor.
wal-mart engine oil is fine if you want......
dang! im i the only one that knows the secret? for a 2cycle motor (or nitro) go to autozone/advance auto and pick up a specter air filter cleaning kit, for like $15 you get two big bottles of cleaner and filter oil. it will last you forever.
blam!
blam!
ORIGINAL: Devils-Reject
OR GET A $2 BOTTLE OF TRANNY FLUID OR jug of 10w40 oil at the dollar store for $3
if you do use oil, use two cylcle oil, still specter oil is the best bet.
My Feedback: (8)
ORIGINAL: The_Shark
meh, i dont like using motor oil, its a bit thick and not stickey enough.
if you use to thick of an oil and it change how your motor runs
