Shockwave rc nitro wont start!!! :(
PA
HI, everyone i have just bought this brand new, and i have done everything to try and get it started, bought a starter kit, fuel, extra glow plugs, did follow up on how to videos but it wont start..the engine is not flooded yet the pull starter is very hard to pull..and when i out the glow plug in and put it in snugg the pull start is also hard to pull, i have only got it started once and this yas yesterday after hours and hours of trying and everything was working fine for about 30-50 seconds and then the engine got really high revved and i had to shut it off, now it wont start again....ugghhh please help!!!!
RE: Shockwave rc nitro wont start!!! :(
Sounds like your fuel line is pinched or it has a pin sized whole in it. Could also be because of the cold weather, take it inside and use a hair dryer to warm the engine.
try a new glow plug. sometimes they die quickly. it wont hurt to try a new one anyway.
the motor should be kinda hard to pull over...even with the glow plug out. it will be easier to pull once its broken-in
click this link, basic tuning.
make sure you follow break in procedure from the manufacture.
[link=http://www.rcuniverse.com/forum/fb.asp?m=10192204]link for tuning.[/link]
PA
OKay thanks guys for the help, Istill cant get it to run..i got it to run last night 2 times b 4 i shut it off cause i thoght it was getting high pitched again, which was stupid of me..and i think i was messing with the needles, and could there be something wrong with my igniter? i have 2 new glow plugs and they both work fine, also, the first night i did get it started there were bubbles in the fuel line, in which i did something ad it squirted out of the carb and it worked, but thats when it gt really high reved and i shut it off, now could it be something wrong with the needled, Its a redcat shockwave, with traxxas fuel. vertex vx.16 engine, Please tell me any other idea's why it wont start? Thanks
i'm pretty sure that most engines come pre set for break in, is this rc new? Keep running it even if you think its getting high piched, nitro motors are pretty loud.
PA
yes it is brand new, and i just cant get it to start... can you give me all your idea's? on why? Thanks
ORIGINAL: turnermic
If you messed with the mixture needles, put them back to what they were at. Once the engine is running, drive it around some until it gets warmed up. Minimum 200*F, Max 240*F.
These engines only need 4 things to run. Fuel, Air, Compression, and a Glowing plug. If the outside temp is colder than say 60*F, use a hair dryer or heat gun to warm the engine up to 90-100*F and it should start better.
One more thing - DONT FORGET to turn the Transmitter and Receiver on! If you don't and your throttle is open, it will take off and subsequently crash.
PA
Thanks, i have tried to heat it up with a blow dryer and that has worked very well, Where i live since its winter it normally 20-30 degrees out, so it is very hard to start, Now in order to start the break in process i need to let it run for 1 full tank first let it cool down, and then do what my manual says?
ORIGINAL: turnermic
In a nutshell - Run it nicely, slightly rich, and get it to 220*. Shut down, cool, and repeat. I go overboard with 10 cycles - you could probably get away with 6-8 and being okay. Doing this has worked well for me and many others.
PA
OKay so your saying i dont have to let it sit on a bloack to do all this, i can actually like what my manual says is do figure eights, at just tiny revs, then it gives you the whole thing on the break in process, its still hard to start its really being a pain in my ____. Thanks for your quick reply
ORIGINAL: turnermic
PA
Alright Thanks, Now say i do this break in process which i know i need to , will it be easier to start?
ORIGINAL: turnermic
All engines should start quickly if all of the conditions are met. Once the engine is broke in, usually you shouldnt have to heat the engine up beforehand if you keep it inside.
PA
Alright sounds good, Now what about this gear mesh? and how do you adjust the brakes? WD40 4 after run oil?
