e10 Touring diff pinion melting...
I have an HPIE10 set up for touring. I have the fiebolt 15t and SC15 ESC, 31mm D compound tires, adjustable oil shocks, sway bar kit, Adjustable control arms, full sealed oiled bearings, and atomic steering kit with homemade adjustable tie rods. Thats just the traction stuff, the rest of the driveline is stock. My problem is, when i throw the 26 tooth motor side pinion in it for some high speed track runs, I almost melt and definatley strip thePinion gear inside the front and rear diff. I cant find a metal one on my own. Any help?
Tracey
Tracey
