help with pull start problem
Hi i pump fuel to the engine but as soon as i put the igniter in the pull start cord gets jammed and i can't start the Rc can you help ??
RE: help with pull start problem
sounds like you have flooded your engine, just take out the glow plug pull it over a few times with a rag/cloth over the top of the engine, put the glow plug back in and it should fire up. this will solve the immediate problem. just don't OVER PRIME the engine. try putting your finger over the exhaust and pulling it over this way you can see when the fuel just gets to the carburator to stop priming!<div>hope this helps :P</div>
