on road tires for bandit?
RE: on road tires for bandit?
A good advice is maybe to buy 17 mm adapters and use 1/8th wheels? Then you have a lot of choices, and you can get them really cheap aswell, glued on rims. They also has less tendencies to balloon as the ones made for Slash.
Banned
PA
lars- i dont really want to use 1/8 tires. they are a little too big.<div></div><div>redfisher- idk probably a maximum of $25.</div>
what purpose for on-road?
i use the bandit (tracer) wheels on my firestorm, with anacondas up front and Panther slicks on the rear. No stability issues at high speed.. no ballooning (taped & hard foam).
1 Post
ORIGINAL: Fuel Crazy
ORIGINAL: redfisher1974
What body is that on your storm?
As it is a long time since i compared the wheel diameter on my then stock Rustler, and some 1/8th wheels, it was so little difference that i didn't bother. Most 1/8th buggywheels are 110 mm in diameter (they are 98 mm on [link=http://www.rcuniverse.com/forum/m_10174051/mpage_2/tm.htm]this car i have modified[/link]), and i think the Rustler stock ones are 108 mm. I don't know where the 108 mm came from, but it popped up in my head right now.
Thanks. Im actually not much of a dodge fan, so its funny to be using a dodge body... but i dont like the stock firestorm bodies much so i changed it over.
Id think just about any 200mm truck body would fit, will just require some modifying. Im not sure if the rear suspension, and mainly the shock tower & body post position is the same between the E-storm and Nitro storm, but if it is...the only thing i had to do was redrill the front holes, then cut out the top of the bed in the rear to allow clearance for the shock tower and shocks.
Right now i actually cant even use this body anymore until i figure out a way to mount some body posts on the rear, because i no longer have the HPIrear suspension or diff in the truck (using entire rear suspension & diff from a Duratrax truck) and the layout is quite a bit different.
is it the same as the Nitro versions? If so, yeah, being so wide and high turns into a clearance issue. But you can always cut opening for it to clear..
I should have no problem with bodys now... you can see the difference in the layout between the stock rear (1st pic) and with the Duratrax rear (2nd pic).
