XL w/ Baja Wheel and OFNA mid tank mod
So i just got done moddin my XL again! To date the mods done are as follow
Converted X to XL- engine plate, dogbones and axles, extended drive cups, and TVP's
BP diffs
BP 3 Speed Tranny mod
ABMods Drag Modded Picco P3 28
ERCM End bleed pipe
Custom Roll bar
OFNA 250cc mid tank mod
Baja wheel mod- 4x Rear Tarmacs
HPI 24mm hex's
CS 170tg steering servo
Custom OFNA throttle mod
Steering servo bearing upgrade
Flux Big Bore Shocks
RPM rear A Arms
Integy Rear uprights
Traxxas Wheelie bar mod
Spektrum 2.0 radio
Pretty much Bullet Proof!!!
BP diffs
ERCM End bleed pipe
Custom Roll bar
HPI 24mm hex's
RPM rear A Arms
Spektrum 2.0 radio
RE: XL w/ Baja Wheel and OFNA mid tank mod
More pics
I just think it looks clean as hell now with the mid tank. Believe it or not the Tarmac Baja wheels actually weigh less than the Goliaths
bro that looks sick!... makes me think twice about converting my x ss to BL
your truck has a real clean custom look to it. real nice
The baja wheels i have are just a tiny bit smaller than the terra pins and goliaths and not as wide.
While running the truck today i noticed that the wheels are very slippery on asphault. The truck slides all over the place and just spins and spins. However on high speed runs these tires are perfect. NO BALLOONING and WOBBLING AT ALL !!! I would say that i picked up at least a mph or two on top end with them. The only thing i need to change is the angle of the tank. While braking the fuel moves forward away from the pick up, Under throttle its fine. So im going to reangle it to fix it. The mid tank lean is gone and the run time is almost 30min.
I used these boxes for my battery and radio
http://www3.towerhobbies.com/cgi-bin...1&I=LR6009&P=K
http://www3.towerhobbies.com/cgi-bin...?&I=LXPZC1&P=7
I personally like the look of these two stacked than the CEN radio box or HPI rush box's Plus it keeps the shock towers clear and im not worried about crashing with them.
That's friggin sweeeet!
I'm starting to get more and more into my stock savage 25. It was barely used when i got it so it's practically new. I was eyeing some big bore shocks and to get a traxxas 2.4 ghz radio/reciever. I don't like the old clunky one mine came with.
What's the benefit of going to the longer chassis? Is it THAT more stable? Are the big bore shocks "out of the box" THAT much better than the stock 8 shocks on a savage 25?
I like the roll cage you came up with...nicely done.
ORIGINAL: smitty2919
What's the benefit of going to the longer chassis? Is it THAT more stable? Are the big bore shocks ''out of the box'' THAT much better than the stock 8 shocks on a savage 25?
ORIGINAL: SLAYERDUDE
That's PIMP dude!
I'm kinda surprised at the size of the Baja tires.. they look normal on there.[X(]
That's PIMP dude!
This is all you need to mount them.... cost me like $30 and some change
http://www.hobbies4life.com/ProductD...Code=HPI102530
